Recommended Home Charger
Minnesota
2023 Premium AWD ER
#2
I’m still using the portable 220v charger since day 1, February 10. Seems to work fine, but I’m thinking of getting the new Chargepoint home charger and keep the portable in the frunk.
Los Angeles
mache2024
#3
I use a Ruivanda home charger, which can be directly plugged into a 240V NEMA 14-50 wall socket. The maximum charging power is 240v✖️48A=10.5KW, which means 10.5 kWh of electricity per hour. Since the battery is generally not completely used up before charging, the charging current can be lowered, which will be safer.
